ARM MP+PPO656 "Fre DMBdWW Rfe PosRR PosRW PosWR DpDatadW PosWR" Cycle=Rfe PosRR PosRW PosWR DpDatadW PosWR Fre DMBdWW Relax= Safe=Rfe Fre PosWR PosRW PosRR DMBdWW DpDatadW Prefetch=1:x=T Orig=Fre DMBdWW Rfe PosRR PosRW PosWR DpDatadW PosWR { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0, #2 | LDR R0, [%y1] ; STR R0, [%x0] | LDR R1, [%y1] ; DMB | MOV R2, #2 ; MOV R1, #1 | STR R2, [%y1] ; STR R1, [%y0] | LDR R3, [%y1] ; | EOR R4,R3,R3 ; | ADD R4, R4, #1 ; | STR R4, [%x1] ; | LDR R5, [%x1] ; Observed 1:R0=1; 1:R5=1; x=2; y=2; and 1:R0=1; 1:R5=2; x=2; y=2;
