Test LB+PPO0036
ARM LB+PPO0036
"PodRW Rfe DpDatadW Rfe PosRR PosRW PosWR DpAddrdR"
Cycle=Rfe PosRR PosRW PosWR DpAddrdR PodRW Rfe DpDatadW
Relax=
Safe=Rfe PosWR PosRW PosRR Pod*W DpAddrdR DpDatadW
Prefetch=
Com=Rf Rf
Orig=PodRW Rfe DpDatadW Rfe PosRR PosRW PosWR DpAddrdR
%z0=z; %x0=x;
%x1=x; %y1=y; %z1=z;
 P0           | P1              ;
 LDR R0,[%z0] | LDR R0,[%x1]    ;
 EOR R1,R0,R0 | LDR R1,[%x1]    ;
 ADD R1,R1,#1 | MOV R2,#2       ;
 STR R1,[%x0] | STR R2,[%x1]    ;
              | LDR R3,[%x1]    ;
              | EOR R4,R3,R3    ;
              | LDR R5,[R4,%y1] ;
              | MOV R6,#1       ;
              | STR R6,[%z1]    ;
Observed
    0:R0=1; 1:R0=1; x=2;
