Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R1=1 ; 1:R3=2 ; x=1 ; y=2"
ARM LB+data+pos-fri-rfi-ctrl+REAL "DpDatadW Rfe PosRR Fri Rfi DpCtrldW Rfe" Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe PosRR Fri Rfi DpCtrldW Rfe { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; LDR R0,[%x0] | LDR R0,[%y1] ; STR R0,[%y0] | LDR R1,[%y1] ; | MOV R2,#2 ; | STR R2,[%y1] ; | LDR R3,[%y1] ; | CMP R3,#2 ; | BNE LC00 ; | MOV R4,#1 ; | STR R4,[%x1] ; | LC00: ; Observed 0:R0=1; 1:R0=1; 1:R1=1; 1:R3=2; x=1; y=2;
