Test LB+data+pos-fri-rfi-ctrl+REAL
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R1=1 ; 1:R3=2 ; x=1 ; y=2"
ARM LB+data+pos-fri-rfi-ctrl+REAL
"DpDatadW Rfe PosRR Fri Rfi DpCtrldW Rfe"
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Rf
Orig=DpDatadW Rfe PosRR Fri Rfi DpCtrldW Rfe
%x0=x; %y0=y;
%y1=y; %x1=x;
 P0           | P1           ;
 LDR R0,[%x0] | LDR R0,[%y1] ;
 STR R0,[%y0] | LDR R1,[%y1] ;
              | MOV R2,#2    ;
              | STR R2,[%y1] ;
              | LDR R3,[%y1] ;
              | CMP R3,#2    ;
              | BNE LC00     ;
              | MOV R4,#1    ;
              | STR R4,[%x1] ;
              | LC00:        ;
Observed
    0:R0=1; 1:R0=1; 1:R1=1; 1:R3=2; x=1; y=2;
