Test LB+data+fri-rfi-addr
 ModelAPQ8060A5XA6XExynos5250Tegra3Exynos4412Exynos5410APQ8064
LB+data+fri-rfi-addrForbidNo, 0/1.4GNo, 0/2.4GNo, 0/2.6GNo, 0/3.4GNo, 0/2.5GNo, 0/4.8GNo, 0/4.6GOk, 110k/5.0G
  Allow unseenAllow unseenAllow unseenAllow unseenAllow unseenAllow unseenAllow unseen
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R2=2 ; y=2"
ARM LB+data+fri-rfi-addr
"DpDatadW Rfe Fri Rfi DpAddrdW Rfe"
Cycle=Rfi DpAddrdW Rfe DpDatadW Rfe Fri
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Rf
Orig=DpDatadW Rfe Fri Rfi DpAddrdW Rfe
%x0=x; %y0=y;
%y1=y; %x1=x;
 P0           | P1              ;
 LDR R0,[%x0] | LDR R0,[%y1]    ;
 EOR R1,R0,R0 | MOV R1,#2       ;
 ADD R1,R1,#1 | STR R1,[%y1]    ;
 STR R1,[%y0] | LDR R2,[%y1]    ;
              | EOR R3,R2,R2    ;
              | MOV R4,#1       ;
              | STR R4,[R3,%x1] ;
Observed
    0:R0=1; 1:R0=1; 1:R2=2; y=2;
