Test LB+data+data-wsi-rfi-ctrl+BIS
 ModelTegra2APQ8060A5XA6XExynos5250Tegra3Exynos4412Exynos5410APQ8064
LB+data+data-wsi-rfi-ctrl+BISForbidNo, 0/5.8GNo, 0/25GNo, 0/14GNo, 0/19GNo, 0/26GNo, 0/48GNo, 0/54GNo, 0/57GOk, 1.2M/58G
  Allow unseenAllow unseenAllow unseenAllow unseenAllow unseenAllow unseenAllow unseenAllow unseen
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R3=2 ; z=2"
ARM LB+data+data-wsi-rfi-ctrl+BIS
"DpDatadW Rfe DpDatadW Wsi Rfi DpCtrldW Rfe"
(* Real control dependency *)
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Rf
Orig=DpDatadW Rfe DpDatadW Wsi Rfi DpCtrldW Rfe
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
 P0           | P1           ;
 LDR R0,[%x0] | LDR R0,[%y1] ;
 EOR R1,R0,R0 | EOR R1,R0,R0 ;
 ADD R1,R1,#1 | ADD R1,R1,#1 ;
 STR R1,[%y0] | STR R1,[%z1] ;
              | MOV R2,#2    ;
              | STR R2,[%z1] ;
              | LDR R3,[%z1] ;
              | CMP R3,#2    ;
              | BNE LC00     ;
              | MOV R4,#1    ;
              | STR R4,[%x1] ;
              | LC00:        ;
Observed
    0:R0=1; 1:R0=1; 1:R3=2; z=2;
