PPC WWC+addrpa+popa "Rfe DpAddrdWPA RfeAP PodRWPA WseAP" Cycle=RfeAP PodRWPA WseAP Rfe DpAddrdWPA Prefetch=0:x=F,2:x=W Com=Rf Rf Ws Orig=Rfe DpAddrdWPA RfeAP PodRWPA WseAP { ok=1; 0:r2=x; 1:r2=x; 1:r5=y; 1:r7=ok; 2:r2=y; 2:r4=x; 2:r6=ok; } P0 | P1 | P2 ; li r1,2 | lwz r1,0(r2) | lwz r1,0(r2) ; stw r1,0(r2) | xor r3,r1,r1 | li r3,1 ; | li r4,1 | lwarx %sta,r0,r4 ; | lwarx %sta,r3,r5 | stwcx. r3,r0,r4 ; | stwcx. r4,r3,r5 | bne Fail2 ; | bne Fail1 | b Exit2 ; | b Exit1 | Fail2: ; | Fail1: | li r5,0 ; | li r6,0 | stw r5,0(r6) ; | stw r6,0(r7) | Exit2: ; | Exit1: | ; exists (ok=1 /\ x=2 /\ 1:r1=2 /\ 2:r1=1)
